How do i burn my vobs to DVD??? I have alot of DTS and Dolby Digital trailers in vobs but i dont know how to burn it! What program do i need? i have the latest nero for burning.
You need programs like vobedit to join the vob files together, and then ifoedit to dreate the ifo and bup files that you will need to make a compliant DVD. Then, when all the files are set, use Nero to burn. Check out the link below. It's actually for joining a two sided DVD, but it should work for what you want to do.
http://ifoedit.wh.fr0zen.com/joinclip.html#joindbl... -
or read my guide
https://www.videohelp.com/forum/userguides/120021.php
basicly the same though...
Save Rendering Time--Change VOB to MPG--Set Audio VOB & MPG2 video files
By jake61 in forum Newbie / General discussionsReplies: 4Last Post: 5th May 2010, 16:12 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 20:10 -
VOB to DV last VOB file finishes in about one second w/no data
By Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 18:39 -
VOB to wav & m2v and back to VOB
By GordRocks in forum Video ConversionReplies: 2Last Post: 13th Jan 2008, 06:44
